[GRASS-dev] Weekly snapshot - link with non-changing name?
Rainer M Krug Rainer at krugs.de
Fri Jun 26 08:15:23 PDT 2015
Vaclav Petras <wenzeslaus at gmail.com> writes:
> On Fri, Jun 26, 2015 at 4:52 AM, Rainer M Krug <Rainer at krugs.de> wrote:
>> Hi Vaclav,
>> > On Mon, Jun 22, 2015 at 9:40 AM, Rainer M Krug <Rainer at krugs.de> wrote:
>> >> Markus Neteler <neteler at osgeo.org> writes:
>> >> >> It is really just a automatic snapshot, not a tested
>> >> >> > release.
>> >> >> Thanks - so I will then use HEAD of the svn - easier to do in
>> homebrew,
>> >> >> as no sha hash is needed of the downloaded file.
>> >> > You want me to generate that?
>> >> No - no need. I just tell homebrew to download head from svn and than to
>> >> compile it - it works.
>> >> I will post a link to the recipe later this week. This will make testing
>> >> of GRASS 7.1 easy on OS X.
>> > And it can be combined with:
>> >     cd /grass/source/code/root
>> >     ./bin.../grass71 ~/grassdata/nc_spm_08/PERMANENT/ \
>> >         --exec python -m grass.gunittest.main \
>> >         --location nc_spm_08 --location-type nc
>> That is a brilliant idea. But as the tests will be run automatically, I
>> need to download the data.
> The download could be added to test execution but I'm not sure about that.
> It would just make it more complex.
I added the sample data as a separate recipe so that the instrallation
is independent.
>> I assume this is the dataset to be used:
>> http://grass.osgeo.org/sampledata/north_carolina/nc_spm_08_grass7.tar.gz
>> Is this correct?
> Yes. Although, there are some inconsistencies (some test fail because they
> expect the basic nc spm). However, this all should change because we should
> switch to the new sample dataset naming scheme [1]. Needless to say,
> volunteers needed.
Just let me know when there are changes.
Thanks,
Rainer
> Vaclav
> [1] https://trac.osgeo.org/grass/wiki/SampleDataset
>> Rainer
>> > Thanks a lot,
>> >> Rainer
>> >> > Markus
>> >> >> Thanks,
>> >> >> Rainer
>> >> >> > Vaclav
>> >> >> > Thanks,
>> >> >> >> Rainer
>> >> >> >> > Rainer
>> >> >> >> >> Markus
>> >> >> >> Rainer M. Krug
>> >> >> >> email: Rainer<at>krugs<dot>de
>> >> >> >> PGP: 0x0F52F982
>> >> >> >> _______________________________________________
>> >> >> >> grass-dev mailing list
>> >> >> >> grass-dev at lists.osgeo.org
>> >> >> >> http://lists.osgeo.org/mailman/listinfo/grass-dev
>> >> >> Rainer M. Krug
>> >> >> PGP: 0x0F52F982
>> >> Rainer M. Krug
>> >> PGP: 0x0F52F982
>> Rainer M. Krug
>> PGP: 0x0F52F982
Rainer M. Krug
PGP: 0x0F52F982
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150626/9a2fa53c/attachment-0001.pgp>
