[GRASS-dev] G7.0.svn: g.remove segfault
Vaclav Petras wenzeslaus at gmail.com
Fri Jun 26 12:03:59 PDT 2015
On Fri, Jun 26, 2015 at 2:37 PM, Sören Gebbert <soerengebbert at googlemail.com
> wrote:
> Hi,
> may i suggest a patch to solve this issue?
Sure!
I'm not sure if I can judge the path. However, sprintf is used a lot in
GRASS, so I'm not sure if we can just replace it with other function
without understanding what is the issue (at least I don't understand).
As for the magic number there, there is G_PATH_MAX or something, perhaps
that would be more appropriate.
If the issue is length of the path, then I understand why it was happening
for the tests - they use long Mapset names and possibly also map long map
names.
> http://pastebin.com/D8yautBh
> Best regards
> Soeren
> 2015-06-26 20:27 GMT+02:00 Sören Gebbert <soerengebbert at googlemail.com>:
> > Hi,
> > here a traceback of a g.remove segfault that happens while testing
> > temporal modules:
> > http://pastebin.com/LDVKgEed
> > Seems to be in M_do_remove calling some sort of sprintf?? Maybe line
> > 102, since the colr2 buffer is only 50 chars in length ... however,
> > sprintf() function shouldn't be used at all.
> > Best regards
> > Soeren
> > 2015-06-26 16:11 GMT+02:00 Vaclav Petras <wenzeslaus at gmail.com>:
> >> On Fri, Jun 26, 2015 at 6:09 AM, Maris Nartiss <maris.gis at gmail.com>
> wrote:
> >>> I can not repeat the issue with current trunk on ~AMD64 Gentoo.
> >>> Please provide locale information; run g.remove under valgrind to see
> >>> the source of memory corruption.
> >> That's the hard part. I cannot run valgrind easily. I'm not getting the
> >> error when I execute it manually (at least not often enough). It is
> >> happening only with some part of tests for me. As I've written before, I
> >> originally haven't reported it at all because I'm getting with one copy
> of
> >> GRASS but not with the other on the same machine without being able to
> find
> >> any difference in between them. (Fortunately the copy which works is
> the one
> >> running the automated tests.) Only after Soeren and now Markus reported
> the
> >> same, I started to lean towards opinion that it is not a local issue.
> >> As for valgrind, that's unfortunately a feature request for gunittest.
> Which
> >> is even more advanced then I expected because valgrind is not need for
> the
> >> tested module but just for a helper one, anyway, the testing framework
> >> should allow that.
> >> I'm not sure if Soeren can repeat it in more direct way.
> >>> Māris.
> >>> 2015-06-25 3:47 GMT+03:00 Vaclav Petras <wenzeslaus at gmail.com>:
> >>> > On Wed, Jun 24, 2015 at 9:29 AM, Vaclav Petras <wenzeslaus at gmail.com
> >>> > wrote:
> >>> >> On Wed, Jun 24, 2015 at 3:12 AM, Markus Neteler <neteler at osgeo.org>
> >>> >> wrote:
> >>> >>> On Wed, Jun 24, 2015 at 9:06 AM, Markus Neteler <neteler at osgeo.org
> >>> >>> wrote:
> >>> >>> > Hi,
> >>> >>> > to my surprise I managed to generate a segfault using g.remove:
> >>> >>> please disregard. Apparently a system update triggered this (no
> idea
> >>> >>> how).
> >>> >>> "make distclean" helped.
> >>> >> Well, you are not the only one with the problem:
> >>> >> https://lists.osgeo.org/pipermail/grass-dev/2015-May/075083.html
> >>> >> I will have to try distclean, although I think I tried it several
> times
> >>> >> before.
> >>> > I'm getting the same issues again. Now I actually see a buffer
> overflow:
> >>> > *** buffer overflow detected ***: g.remove terminated
> >>> > ======= Backtrace: =========
> >>> > /lib/x86_64-linux-gnu/libc.so.6(+0x7338f)[0x7fc697b2b38f]
> >>> > /lib/x86_64-linux-gnu/libc.so.6(__fortify_fail+0x5c)[0x7fc697bc2c9c]
> >>> > /lib/x86_64-linux-gnu/libc.so.6(+0x109b60)[0x7fc697bc1b60]
> >>> > /lib/x86_64-linux-gnu/libc.so.6(+0x109069)[0x7fc697bc1069]
> /lib/x86_64-linux-gnu/libc.so.6(_IO_default_xsputn+0xbc)[0x7fc697b3370c]
> >>> > /lib/x86_64-linux-gnu/libc.so.6(_IO_vfprintf+0x26b0)[0x7fc697b043a0]
> >>> > /lib/x86_64-linux-gnu/libc.so.6(__vsprintf_chk+0x84)[0x7fc697bc10f4]
> >>> > /lib/x86_64-linux-gnu/libc.so.6(__sprintf_chk+0x7d)[0x7fc697bc104d]
> >>> > /home/vpetras/dev/grass/trunk/dist.x86_64-unknown-linux-gnu/lib/
> libgrass_manage.7.1.svn.so(M_do_remove+0
> >>> > x2e8)[0x7fc6982e9148]
> >>> > g.remove(main+0x68d)[0x401c5d]
> /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf5)[0x7fc697ad9ec5]
> >>> > g.remove[0x401e3e]
> >>> > ======= Memory map: ========
> >>> > 00400000-00403000 r-xp 00000000 08:11 16127189
> >>> > ist.x86_64-unknown-linux-gnu/bin/g.remove
> >>> > 00602000-00603000 r--p 00002000 08:11 16127189
> >>> > 00603000-00604000 rw-p 00003000 08:11 16127189
> >>> > It fails with a lot of tests but with many other it works. I'm not
> sure
> >>> > if
> >>> > all errors are stack overflow but I could catch all output the a fine
> >>> > next
> >>> > time.
> >>> > Vaclav
> >>> > _______________________________________________
> >>> > grass-dev mailing list
> >>> > grass-dev at lists.osgeo.org
> >>> > http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150626/285a0551/attachment.html>
