[GRASS-dev] [GRASS GIS] #2634: 'utf8' codec can't decode byte 0xf6 in position 8: invalid start byte
GRASS GIS trac at osgeo.org
Mon Jun 29 03:48:07 PDT 2015
  Reporter:  hellik    |      Owner:  grass-dev@…
      Type:  defect    |     Status:  new
  Priority:  critical  |  Milestone:  7.0.1
 Component:  Default   |    Version:  svn-trunk
Resolution:            |   Keywords:  utf, wxgui
       CPU:  x86-32    |   Platform:  MSWindows 7
Comment (by martinl):
 Replying to [comment:10 martinl]:
 > Replying to [comment:9 marisn]:
 > adding just a u' ' would not introduce problems elsewhere :( Backporting
 r64834 could help in some cases but an overhaul of any string processing
 in wxgui is required with strict rules (that need to be created).
 > it's already done in r65462
 Helmut, could you please test current 7.0.1svn if it still works (1)?
 (1) http://wingrass.fsv.cvut.cz/grass70/
Ticket URL: <https://trac.osgeo.org/grass/ticket/2634#comment:11>
