[GRASS-dev] Select vector feature - Error
Moritz Lennert mlennert at club.worldonline.be
Tue Mar 3 00:45:51 PST 2015
On 02/03/15 11:28, Margherita Di Leo wrote:
> Hi,
> when i try to select a feature with the "select vector feature" button
> from map display, I get an Error pop up that reads:
> Error occured during calling of handler: _onMapClickHandler
> Handler was unregistered.
> Reason: VectorSelectBase instance has no attribute 'map'
> Traceback (most recent call last):
>    File "/usr/local/grass-7.1.svn/gui/wxpython/mapwin/base.py", line
> 191, in HandlersCaller
>      handler(event)
>    File "/usr/local/grass-7.1.svn/gui/wxpython/gui_core/vselect.py",
> line 187, in _onMapClickHandler
>      vWhatDic = self.QuerySelectedMap()
> line 272, in QuerySelectedMap
>      message=_("Failed to query vector map(s) <%s>.") % self.map)
> AttributeError: VectorSelectBase instance has no attribute 'map'
I cannot reproduce using freshly checked out trunk and the NC dataset.
BTW, two remarks for enhancement:
- It would be nice if the tool allowed to select also by drawing a
polygon, not only by clicking.
- There is no close button on the little window listing the selected
features.
Moritz
