[GRASS-dev] [GRASS GIS] #2608: Launching Python script on Windows fails with missing freeze_support
GRASS GIS trac at osgeo.org
Wed Mar 4 09:54:32 PST 2015
 Reporter:  marisn       |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:
Component:  Python       |     Version:  7.0.0
 Keywords:               |    Platform:  MSWindows Vista
      Cpu:  Unspecified  |
 Launch the following script on Windows:
 from grass.pygrass.modules.shortcuts import raster as r
 r.mapcalc("rand0 = round(rand(0,1))", s=True)
 r.neighbors(input="rand0", output="count", method="count")
 r.mapcalc("rand1 = if (count > 3, 1, null())")
 r.mapcalc("rand2 = if (count < 1, 1, null())")
 and observe an error:
 C:\Users\tests\Documents\rand.py
   File "<string>", line 1, in <module>
   File "C:\Program Files\GRASS GIS
 7.0.0\Python27\lib\multiprocessing\forking.py", line 380, in
 main
     prepare(preparation_data)
 7.0.0\Python27\lib\multiprocessing\forking.py", line 495, in
 prepare
     '__parents_main__', file, path_name, etc
   File "C:\Users\tests\Documents\rand.py", line 2, in
 <module>
 7.0.0\etc\python\grass\pygrass\modules\interface\module.py",
 line 616, in __call__
     return self.run()
 line 714, in run
     get_msgr().debug(1, self.get_bash())
 7.0.0\etc\python\grass\pygrass\messages\__init__.py", line
 352, in get_msgr
     _instance[0] = Messenger(*args, **kwargs)
 175, in __init__
     self.start_server()
 185, in start_server
     self.server.start()
 7.0.0\Python27\lib\multiprocessing\process.py", line 130, in
 start
     self._popen = Popen(self)
 7.0.0\Python27\lib\multiprocessing\forking.py", line 258, in
 __init__
     cmd = get_command_line() + [rhandle]
 7.0.0\Python27\lib\multiprocessing\forking.py", line 358, in
 get_command_line
     is not going to be frozen to produce a Windows executable.''')
 RuntimeError:
             Attempt to start a new process before the current process
             has finished its bootstrapping phase.
             This probably means that you are on Windows and you have
             forgotten to use the proper idiom in the main module:
                 if __name__ == '__main__':
                     freeze_support()
             The "freeze_support()" line can be omitted if the program
Ticket URL: <http://trac.osgeo.org/grass/ticket/2608>
