[GRASS-dev] [GRASS GIS] #2618: v.vector option=transfer does not copy multiple cat values
GRASS GIS trac at osgeo.org
Mon Mar 9 07:40:17 PDT 2015
 Reporter:  ulf                  |       Owner:  grass-dev@…
     Type:  defect               |      Status:  new
 Priority:  normal               |   Milestone:  7.0.1
Component:  Vector               |     Version:  7.0.0
 Keywords:  v.category transfer  |    Platform:  Linux
      Cpu:  x86-64               |
 v.vector with option=transfer only copies one category value when a
 feature has multiple category values in the same layer. An example to
 explain what I mean:
 echo "100|100|1" | v.in.ascii output=test input=-
 fid=$(v.edit --quiet layer=1 map=test tool=select cat=1)
 v.edit map=test layer=1 tool=catadd ids=${fid} cats=2
 Now,
 v.category option=print layer=1 input=test2
 outputs "1/2", but
 v.category option=print layer=2 input=test2
 outputs "1".  I would expect "1/2"...
Ticket URL: <http://trac.osgeo.org/grass/ticket/2618>
