[GRASS-dev] what happened to r.out.arc?
Michael Barton Michael.Barton at asu.edu
Mon Mar 9 15:20:13 PDT 2015
So AAIGrid is the newish name for ESRI in gdal I guess. In tests today, it has the same problem as before.
The null values need to be specified as -9999. This is not a big problem. Just a little annoyance.
Sometimes it exports different headers that are not compatible with NetLogo raster ingest. Perhaps this is the only program that has a problem but maybe not.
Sometimes it exports a header with a single “cellsize” line (which is what r.out.arc always did and what NetLogo expects) and other times it exports 2 lines “dx” and “dy”.
Of course someone can go in and edit the header but it makes for confusing output that sometimes works and sometimes does not.
Michael
______________________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Head, Graduate Faculty in Complex Adaptive Systems Science
Arizona State University
Tempe, AZ  85287-2402
USA
voice:  480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax:          480-965-7671(SHESC), 480-727-0709 (CSDC)
www:  http://csdc.asu.edu, http://shesc.asu.edu
http://www.public.asu.edu/~cmbarton
On Mar 9, 2015, at 2:59 PM, Anna Petrášová <kratochanna at gmail.com<mailto:kratochanna at gmail.com>> wrote:
On Mon, Mar 9, 2015 at 5:55 PM, Michael Barton <Michael.Barton at asu.edu<mailto:Michael.Barton at asu.edu>> wrote:
It did not do it well before and we are having trouble finding what to pick to get this (it doesn’t help that the list of output formats is not sorted for some reason). We don’t see an ESRI ASCII or ASC format.
AAIGrid (rw): Arc/Info ASCII Grid?
Michael
C. Michael Barton
USA
voice:  480-965-6262<tel:480-965-6262> (SHESC), 480-965-8130<tel:480-965-8130>/727-9746 (CSDC)
fax:          480-965-7671<tel:480-965-7671>(SHESC), 480-727-0709<tel:480-727-0709> (CSDC)
www:  http://csdc.asu.edu<http://csdc.asu.edu/>, http://shesc.asu.edu<http://shesc.asu.edu/>
On Mar 9, 2015, at 2:50 PM, Anna Petrášová <kratochanna at gmail.com<mailto:kratochanna at gmail.com>> wrote:
On Mon, Mar 9, 2015 at 5:47 PM, Michael Barton <Michael.Barton at asu.edu<mailto:Michael.Barton at asu.edu>> wrote:
r.out.arc has disappeared from GRASS 7 and it is not at all clear what other module will output ESRI ASCII format. We need that to feed into NetLogo but it is also a pseudo-standard.
r.out.gdal does not do that?
Anna
Any suggestions?
Michael
C. Michael Barton
USA
grass-dev mailing list
grass-dev at lists.osgeo.org<mailto:grass-dev at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150309/0983062d/attachment-0001.html>
