[GRASS-dev] [GRASS GIS] #2579: Specify command to be exectued as parameter of grass command
GRASS GIS trac at osgeo.org
Mon Mar 9 20:46:26 PDT 2015
 Reporter:  wenzeslaus                        |       Owner:  grass-dev@…
     Type:  enhancement                       |      Status:  new
 Priority:  normal                            |   Milestone:  7.1.0
Component:  Startup                           |     Version:  svn-trunk
 Keywords:  batch job, GRASS_BATCH_JOB, init  |    Platform:  All
      Cpu:  Unspecified                       |
Comment(by wenzeslaus):
 Replying to [comment:4 martinl]:
 > Replying to [comment:3 rkrug]:
 > > I guess there is no chance that it can be included into GRASS 7?
 > I would say no for GRASS 7.0, the issue is focused on GRASS 7.1 I would
 say.
 Right, the I've already set the milestone to 7.1.0.
 Feedback for the command line syntax would be appreciated to move this
 forward and is necessary before including to trunk (which should be done
 and before the patch becomes incompatible).
Ticket URL: <http://trac.osgeo.org/grass/ticket/2579#comment:7>
