[GRASS-dev] [GRASS GIS] #2579: Specify command to be exectued as parameter of grass command
GRASS GIS trac at osgeo.org
Tue Mar 10 01:45:37 PDT 2015
 Reporter:  wenzeslaus                        |       Owner:  grass-dev@…
     Type:  enhancement                       |      Status:  new
 Priority:  normal                            |   Milestone:  7.1.0
Component:  Startup                           |     Version:  svn-trunk
 Keywords:  batch job, GRASS_BATCH_JOB, init  |    Platform:  All
      Cpu:  Unspecified                       |
Comment(by rkrug):
 Some remarks concerning the syntax:
 1) I don't like the idea of having to repeat the mapset each time as it
 will require quite a bit of typing and possible errors in longer scripts.
 So the assumption to use the mapset which is in the rc file (i.e., if I am
 correct, the one used before), would be quite useful.
 2) Instead of using the normal `grass` command, I would suggest to
 introduce a new command(e.g. {{{ggrassbatch}}}), which is taking only one
 parameter: the command to be executed including the parameter. So it could
 be used as
 {{{grassbatch r.info}}}
 3) The function {{{grassbatch}}} should accept, in addition to the normal
 grass commands, one more command named e.g. {{{set.mapset}}} which is only
 doing one thing, setting the mapset in the rc file, so this would be the
 mapset to be used for all following {{{grassbatch}}} commands, unless the
 mapset is changed.
 So a script could look as followed:
 grassbatch set.mapset ~/grassdata/nc_spm_08_grass7/user1
 grassbatch .../test_script.sh
 grassbatch r.info
 grassbatch r.mapcalc "aaa = 5"
Ticket URL: <http://trac.osgeo.org/grass/ticket/2579#comment:8>
