[GRASS-dev] problem with grass7 package and Ubuntu 12.04
Luca Delucchi lucadeluge at gmail.com
Tue Mar 10 09:12:03 PDT 2015
On 10 March 2015 at 16:35, Sebastiaan Couwenberg <sebastic at xs4all.nl> wrote:
>> hm, I already tried to install `grass7` on Ubuntu 12.04 and it worked.
>> So how to fix it for the user? Martin
> If package works on plain Ubuntu without PPAs then the user needs to check
> which PPAs he's using that's causing the dependency problem. Start by
> disabling all PPAs except GRASS.
ok, I also tested in a clean docker ubuntu 12.04.
With only GRASS PPA it doesn't work; with ubuntugis-unstable and
ubuntugis-stable it works. So I'll suggest to disabling all PPAs
except GRASS and ubuntugis-unstable/stable
> Kind Regards,
> Bas
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
