[GRASS-dev] [GRASS GIS] #2617: wxgui Raster query redirect to console UnicodeDecodeError
GRASS GIS trac at osgeo.org
Tue Mar 10 23:43:49 PDT 2015
 Reporter:  marisn           |       Owner:  grass-dev@…
     Type:  defect           |      Status:  new
 Priority:  normal           |   Milestone:  7.0.1
Component:  wxGUI            |     Version:  svn-trunk
 Keywords:  query, encoding  |    Platform:  MSWindows Vista
      Cpu:  Unspecified      |
Comment(by marisn):
 Just dropping a note here as it needs further investigation:
 https://docs.python.org/2/library/gettext.html#gettext-vs-lgettext
   In Python 2.4 the lgettext() family of functions were introduced. The
 intention of these functions is to provide an alternative which is more
 compliant with the current implementation of GNU gettext. Unlike
 '''gettext(), which returns strings encoded with the same codeset used in
 the translation file''', lgettext() will return strings encoded with the
 preferred system encoding, as returned by locale.getpreferredencoding().
 Also notice that Python 2.4 introduces new functions to explicitly choose
 the codeset used in translated strings. If a codeset is explicitly set,
 even lgettext() will return translated strings in the requested codeset,
 as would be expected in the GNU gettext implementation.
 Note on "same codeset" explains where the UTF-8 strings are coming from
 and why it differs from C implementation of gettext.
 In the aforementioned document is also another one interesting remark:
 https://docs.python.org/2/library/gettext.html#the-gnutranslations-class
   Note that the Unicode version of the methods (i.e. ugettext() and
 ungettext()) are the recommended interface to use for internationalized
 Python programs.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2617#comment:4>
