[GRASS-dev] compile gdal with grass
Michel Wortmann wortmann at pik-potsdam.de
Wed Mar 11 03:48:34 PDT 2015
Ok thanks for info, Bas, and sorry for the Ubuntu noise. I'll get in
touch with the ubuntuGIS list then, I'd be happy to build packages at
least for the new Ubuntu LTS 14.04 although I'm a packaging newbie.
Regards,
Michel
On 03/11/2015 10:55 AM, Sebastiaan Couwenberg wrote:
>> Hi Martin and list,
>> would it be possible to reflect these changes in the Ubuntu packages on
>> the gdal launchpad (ubuntugis-unstable) and making them compatible with
>> the grass7 packages?
> You should direct this question to the UbuntuGIS list.
>> I tried building gdal 1.11.2 --with-grass against preinstalled grass7
>> packages (Ubuntu 14.04), but the grass7 (and qgis for that matter) are
>> still depending on gdal-1.11.1. Now just to be able to browse the GRASS
>> database in QGIS it would make it necessary to build all three from
>> source. Or are there any ideas on avoiding that? The gdal-grass plugin
>> unfortunately doesnt work with grass-7.
> The libgdal-grass Debian package has support for GRASS 7, but since
> UbuntuGIS is highly understaffed, there is hardly anyone actively
> maintaining the packages there.
> If you care about GIS software on Ubuntu, consider contributing the
> UbuntuGIS packaging. It's probably a good idea if the GRASS upstream
> packagers actively contribute to the GRASS packages in UbuntuGIS like jef
> does for QGIS.
> Kind Regards,
> Bas
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
