[GRASS-dev] [GRASS GIS] #2617: wxgui Raster query redirect to console UnicodeDecodeError
GRASS GIS trac at osgeo.org
Thu Mar 12 01:23:01 PDT 2015
 Reporter:  marisn                            |       Owner:  grass-dev@…
     Type:  defect                            |      Status:  new
 Priority:  normal                            |   Milestone:  7.0.1
Component:  wxGUI                             |     Version:  svn-trunk
 Keywords:  query, encoding, python, gettext  |    Platform:  MSWindows Vista
      Cpu:  Unspecified                       |
Comment(by glynn):
 Replying to [comment:6 zarch]:
 > We have to do this work in any case for python3.
 If we actually use it. For most scripting tasks, Python 3 offers nothing
 but inconvenience.
 And even then, there's a much simpler way to deal with it: convert unicode
 strings to byte strings at the point they arise (there are far fewer of
 these compared to the number of places where we will need to write byte
 strings to streams or pass them as command arguments).
 > We can create a function that explicity convert every input to unicode,
 something like:
 But why bother? At the lowest level, scripts tend to do two things: invoke
 commands and read/write streams. Both of these deal with byte strings.
 Converting to unicode then back again just creates unnecessary failure
 modes; there's no guarantee that data read from a given stream will be in
 the locale's encoding, or even in any known encoding.
 wxGUI has to deal with this because wxPython uses Unicode throughout (and
 look how many wxGUI issues relate to Unicode{Encode,Decode}Error as a
 result). The scripting library doesn't need to deal with this; there's no
 inherent reason why most scripts should ever encounter a unicode value.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2617#comment:8>
