[GRASS-dev] [GRASS GIS] #2448: Fontconfig error with cairo on Windows
GRASS GIS trac at osgeo.org
Thu Mar 12 16:19:28 PDT 2015
 Reporter:  annakrat                       |       Owner:  grass-dev@…
     Type:  defect                         |      Status:  new
 Priority:  normal                         |   Milestone:  7.0.1
Component:  Display                        |     Version:  7.0.0
 Keywords:  font, text, legend, scale bar  |    Platform:  MSWindows 8
      Cpu:  Unspecified                    |
Comment(by hellik):
 Replying to [comment:12 annakrat]:
 > I made a screencast to see what's in the terminal which just flashes
 during the installation. I get:
 > Setup of WinGRASS-7.0.0
 > Generating the font configuration file by scanning various directories
 for fonts
 > Please wait. Console window will close automatically ....
 > ERROR: GISRC - variable not set
 > This is the same what happens if you run run_gmkfontcap from windows
 command prompt.
 is this a fresh system without any previous winGRASS-installation before?
 I've added gmkfontcap.bat (''Run g.mkfontcap outside a grass session
 during installation'') years ago.
 relevant lines of codes
 [http://trac.osgeo.org/grass/browser/grass/trunk/mswindows/GRASS-
 Installer.nsi.tmpl#L531 g.mkfontcap] and following.
 534             IfErrors done_create_run_gmkfontcap.bat
 535             FileWrite $0 '@echo off$\r$\n'
 536             FileWrite $0 'rem
 #########################################################################$\r$\n'
 537             FileWrite $0 'rem #$\r$\n'
 538             FileWrite $0 'rem # Run g.mkfontcap outside a grass
 session during installation$\r$\n'
 539             FileWrite $0 'rem #$\r$\n'
 540             FileWrite $0 'rem
 541             FileWrite $0 'echo Setup of
 WinGRASS-${VERSION_NUMBER}$\r$\n'
 542             FileWrite $0 'echo Generating the font configuration file
 by scanning various directories for fonts.$\r$\n'
 543             FileWrite $0 'echo Please wait. Console window will close
 automatically ....$\r$\n'
 544             FileWrite $0 '$\r$\n'
 545             FileWrite $0 'rem set gisbase$\r$\n'
 546             FileWrite $0 'set GISBASE=$INSTALL_DIR$\r$\n'
 547             FileWrite $0 '$\r$\n'
 548             FileWrite $0 'rem set path to freetype dll$\r$\n'
 549             FileWrite $0 'set
 FREETYPEBASE=$INSTALL_DIR\extrabin;$INSTALL_DIR\msys\bin;$INSTALL_DIR\lib$\r$\n'
 550             FileWrite $0 '$\r$\n'
 551             FileWrite $0 'rem set dependecies path$\r$\n'
 552             FileWrite $0 'set PATH=%FREETYPEBASE%;%PATH%$\r$\n'
 553             FileWrite $0 '$\r$\n'
 554             FileWrite $0 'rem run g.mkfontcap outside a grass
 session$\r$\n'
 555             FileWrite $0 '"%GISBASE%\bin\g.mkfontcap.exe" -o$\r$\n'
 556             FileWrite $0 'exit$\r$\n'
 557             FileClose $0
 any idea which variable isn't set?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2448#comment:13>
