[GRASS-dev] [GRASS GIS] #2623: GRASS won't start after creating addons
GRASS GIS trac at osgeo.org
Sat Mar 14 11:45:38 PDT 2015
 Reporter:  ewcgrass                         |       Owner:  grass-dev@…
     Type:  defect                           |      Status:  new
 Priority:  normal                           |   Milestone:  7.0.1
Component:  Default                          |     Version:  unspecified
 Keywords:  menu, toolboxes, addon, loading  |    Platform:  Unspecified
      Cpu:  Unspecified                      |
Comment(by ewcgrass):
 This is from Help-->about system:
 GRASS version: 7.0.1svn
 GRASS SVN Revision: 64713
 Build Date: 2015-01-21
 Build Platform: x86_64-unknown-linux-gnu
 GDAL/OGR: 1.6.3
 PROJ.4: 4.7.0
 GEOS: 3.2.0
 SQLite: 3.7.13
 Python: 2.7.0
 wxPython: 2.8.12.0
 Platform: Linux-2.6.35.14-106.fc14.x86_64-x86_64-with-fedora-14-Laughlin
 (please note that the build date shown above is incorrect and should read
 2015-02-21)
 I have by process of elimination determined that it is the section of the
 $HOME/.grass7/addons/modules.xml file for "r.to.vect.lines" addon that is
 causing grass to not start:
     <task name="r.to.vect.lines">
         <description>None</description>
         <keywords>None</keywords>
         <binary>
             <file>/home/rick/.grass7/addons/scripts/r.to.vect.lines</file>
 <file>/home/rick/.grass7/addons/docs/man/man1/r.to.vect.lines.1</file>
 <file>/home/rick/.grass7/addons/docs/html/r_to_vect_lines_example.png</file>
 <file>/home/rick/.grass7/addons/docs/html/r.to.vect.lines.html</file>
         </binary>
         <libgis revision="64007" />
     </task>
 Removing this section from the file now allows grass to start. However, I
 see no menu items for any of the installed addons. Should there be menu
 items for the addons? And if so, where in the gui would I find them?
 I have attached the $HOME/.grass7/modules.xml file that now allows grass
 to start.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2623#comment:2>
