[GRASS-dev] Linke turbidity in r.sun.daily
Vaclav Petras wenzeslaus at gmail.com
Mon Mar 23 06:49:32 PDT 2015
On Sun, Mar 22, 2015 at 10:40 AM, Nikos Alexandris <nik at nikosalexandris.net>
wrote:
> Vaclav Petras wrote:
>   It would be good if you can look to r.sun which other options you can
>>>>> include.
> Nikos Alexandris wrote:
>  I am.  I am also renaming stuff, eg slope_in to slope. I guess this is
>>>> wanted.
> VP:
>  It should be slope (and slope_value) in the options but I think that's
>>> already true. How the variables in the script are named is not as
>>> important. It's nice when they are consistent with inputs but there can
>>> be
>>> some reasons for the opposite.
> NA:
>  If there are reasons, in this, case, please share.
There is none unless you hit some issue or something.
> Also:  is the
>> intention to have one script for both G7x and G64x?
It was just simpler at the time of writing. Now there is probably no need
to have G6 support since G7 is out.
> I would like to
>> know, while I am at it, to structure appropriately the addition of
>> "linke".
>  The script works for me, with support for linke now. Will share later
>> my working status.
> Modified script attached,
Please share also the diff.
> support only for G7.
> If you will not add G6 support then remove all G7/G6 related if statements.
Nikos
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150323/4c017e32/attachment.html>
