[GRASS-dev] QGIS GRASS Plugin Upgrade Crowdfunding
Pietro peter.zamb at gmail.com
Mon Mar 23 23:00:14 PDT 2015
Hi Radim,
together with Francesco Geri, last week we started to write a first
draft that generate the GUI for the GRASS module dynamically (based on
the xml generated with: --interface-description), so far it is based
on grass7 but should work also on grass6 (not tested, should be enough
to backport the pygrass.modules.Module class).
Best regards
Pietro
On Mon, Mar 23, 2015 at 7:56 PM, Radim Blazek <radim.blazek at gmail.com> wrote:
> Hi all,
> I have finally launched the crowdfunding campaign to support the GRASS
> plugin upgrade. Briefly, it covers upgrade to GRASS 7, browser
> integration, drag-and-drop import and new vector editing. All the
> details are available here:
>     http://www.gissula.eu/qgis-grass-plugin-crowdfunding/
> Please propagate this info to all relevant channels, national mailing lists etc.
> Radim
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
