[GRASS-dev] [GRASS GIS] #2637: Get direction raster in clockwise degrees starting from the North
GRASS GIS trac at osgeo.org
Fri Mar 27 09:03:04 PDT 2015
 Reporter:  cgravelm     |       Owner:  grass-dev@…
     Type:  enhancement  |      Status:  new
 Priority:  normal       |   Milestone:  7.0.1
Component:  Raster       |     Version:  7.0.0
 Keywords:               |    Platform:  MacOSX
      Cpu:  Unspecified  |
Comment(by glynn):
 Replying to [comment:1 annakrat]:
 > You can just use r.mapcalc "angle_cw = -angle_ccw + 450", this will give
 you what you need. It outputs angles from 90 to 450, but that's typically
 not a problem.
 Or, if you want to limit the range to 0..360, use:
 r.mapcalc "angle_cw = (450 - angle_ccw) % 360"
 Similarly, if you want -180..180 (again, clockwise from North):
 r.mapcalc "angle_cw = (630 - angle_ccw) % 360 - 180"
 Similar formulae can be used for any other convention. The main caveat is
 that the left-hand operand to the % (modulo) operator needs to be non-
 negative in order to obtain a non-negative result.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2637#comment:6>
