[GRASS-dev] GDAL-GRASS-plugin 1.11.2
Markus Neteler neteler at osgeo.org
Mon Mar 30 09:16:16 PDT 2015
On Mon, Mar 30, 2015 at 5:22 PM, Blumentrath, Stefan
<Stefan.Blumentrath at nina.no> wrote:
> I also got an error on “sudo make install”:
> cp: cannot stat ‘/usr/local/grass-7.0.1svn/etc/ellipse.table’: No such file
> or directory
> make: *** [install] Error 1
The path changed between G6 and G7, it should be
etc/proj/*
@Martin, is this fixed as well?
thanks
Markus
