[GRASS-dev] g.remove usage syntax
Margherita Di Leo diregola at gmail.com
Tue May 5 05:28:46 PDT 2015
On Tue, May 5, 2015 at 3:30 AM, Martin Landa <landa.martin at gmail.com> wrote:
> Hi,
> 2015-05-05 12:28 GMT+02:00 Margherita Di Leo <diregola at gmail.com>:
> > being name one of the two options (name, pat) that could be identifier=
> or
> > something better. In this case, it would be possible to type the former
> > command or the extended form:
> > g.remove type=vect identifier=name name=foo -f
> > or
> > g.remove type=vect identifier=pattern name="f*" -f
> > (g.remove vect pat "f*" -f)
> > what do you think?
> no idea, in any case it's issue for GRASS 8. Martin
Sure. Is there any place (track? wiki?) already where to collect and
discuss ideas? I saw recently in ML another post about r.shaded.relief, I
haven't followed up but perhaps also that discussion could be included.
Thanks
Best regards,
Dr. Margherita DI LEO
Scientific / technical project officer
European Commission - DG JRC
Institute for Environment and Sustainability (IES)
Via Fermi, 2749
I-21027 Ispra (VA) - Italy - TP 261
Tel. +39 0332 78 3600
margherita.di-leo at jrc.ec.europa.eu
Disclaimer: The views expressed are purely those of the writer and may not
in any circumstance be regarded as stating an official position of the
European Commission.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150505/97760e0e/attachment.html>
