[GRASS-dev] Error launching wxGUI in 7.0.1 r65194
Vaclav Petras wenzeslaus at gmail.com
Fri May 8 20:47:00 PDT 2015
On Wed, May 6, 2015 at 4:02 PM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> On Wed, May 6, 2015 at 3:02 PM, Eric Patton <epatton at nrcan.gc.ca> wrote:
> > Hi,
> > I am using a fresh checkout of Grass 7.0.1 r65194, and it compiled with
no errors
> > (error.log is empty).
In r65199 I added additional checks during compilation. An invalid XML
should show up in the output in case it occurs.
http://trac.osgeo.org/grass/changeset/65199
> > Machine details:
> > uname -a Linux W5-DAR-EPATTON 3.13.0-24-generic #47-Ubuntu SMP Fri May 2
> > 23:30:00 UTC 2014 x86_64 x86_64 x86_64 GNU/Linux
> > Traceback (most recent call last):
> > File "/usr/local/grass-7.0.1svn/gui/wxpython/wxgui.py", line 142, in
<module> sys.exit(main())
> > File "/usr/local/grass-7.0.1svn/gui/wxpython/wxgui.py", line 134, in
main app = GMApp(workspaceFile)
> > File "/usr/local/grass-7.0.1svn/gui/wxpython/wxgui.py", line 49, in
__init__ wx.App.__init__(self, False)
> > File
"/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode/wx/_core.py", line
7981, in __init__ self._BootstrapApp()
> > File
7555, in _BootstrapApp return _core_.PyApp__BootstrapApp(*args, **kwargs)
> > File "/usr/local/grass-7.0.1svn/gui/wxpython/wxgui.py", line 83, in
OnInit workspace = self.workspaceFile)
> > File "/usr/local/grass-7.0.1svn/gui/wxpython/lmgr/frame.py", line 121,
in __init__ self._moduleTreeBuilder = LayerManagerModuleTree()
> > File "/usr/local/grass-7.0.1svn/gui/wxpython/lmgr/menudata.py", line
62, in __init__ MenuTreeModelBuilder.__init__(self, filename,
expandAddons=expandAddons)
> > File "/usr/local/grass-7.0.1svn/gui/wxpython/core/menutree.py", line
66, in __init__ expAddons(xmlTree)
> > File "/usr/local/grass-7.0.1svn/gui/wxpython/core/toolboxes.py", line
346, in expandAddons _expandRuntimeModules(root, loadMetadata=True)
596, in _expandRuntimeModules desc, keywords = _loadMetadata(name)
629, in _loadMetadata task = gtask.parse_interface(module)
> > File "/usr/local/grass-7.0.1svn/etc/python/grass/script/task.py", line
509, in parse_interface tree =
etree.fromstring(get_interface_description(name))
> > File "/usr/lib/python2.7/xml/etree/ElementTree.py", line 1300, in XML
parser.feed(text)
> > File "/usr/lib/python2.7/xml/etree/ElementTree.py", line 1642, in feed
self._raiseerror(v)
> > File "/usr/lib/python2.7/xml/etree/ElementTree.py", line 1506, in
_raiseerror raise err xml.etree.ElementTree.ParseError: not well-formed
(invalid token): line 17, column 19
Now I see that the error goes from grass.script.task.parse_interface (when
called to get XML descriptions of modules installed from addons). I'm not
sure why it is getting invalid XML from get_interface_description which
itself seems to handle error well (return code and OSError are handled). I
added an additional check to parse_interface in r65200.
http://trac.osgeo.org/grass/changeset/65200
> > Any ideas on what is going wrong?
Now I think that some addon you have is not working properly. This might be
caused just by switching between different version of GRASS GIS inside 7
series (e.g. release and build from source code).
If the fix is correct, now a message should appear in the command line
during start instead of the traceback. It will say that it is caused by
addons and you should rebuild the addons using g.extension.all -f but you
should first try the fix before running the command (it would be great if
you could in this way test the fix). Note the changes are only in trunk.
I hope this helps,
Vaclav
> Please do lsb_release -a.
> Then check if there is something in ~/.grass7/toolboxes/. (There could be
something in case you experimented with toolboxes.)
> Also look back in the compilation output you will find there section
where there are some compilations of gui/wxpython code to .pyc. Then there
should be parts which are comping toolboxes. Compilation holds there for a
while with line ending with something like module_items.xml. Checking this
might be useful in case there is something which should be an error but it
is not.
> I don't have better idea now (I just checked release branch and it works
for me).
> Vaclav
> > ~ Eric.
> > grass-dev mailing list
> > grass-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150508/4b986bc8/attachment.html>
