[GRASS-dev] [GRASS GIS] #2671: r.surf.idw won't make interpolation
GRASS GIS trac at osgeo.org
Sat May 9 13:05:24 PDT 2015
  Reporter:  kuszinger  |      Owner:  grass-dev@…
      Type:  defect     |     Status:  new
  Priority:  normal     |  Milestone:  7.1.0
 Component:  Raster     |    Version:  svn-trunk
Resolution:             |   Keywords:  interpolation, e.surf.idw
       CPU:  x86-64     |   Platform:  Linux
Comment (by annakrat):
 Replying to [comment:1 kuszinger]:
 > Test data is accessible here:  [http://www.giscom.hu/debugfrom.pack].
 > 4.4 MB and I tested r.surf.idw against it with the command above. Output
 was the same as input.
 Confirmed. Does it work in 6.4? What example did you use with NC dataset?
 I was not able to make it work.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2671#comment:2>
