[GRASS-dev] inconsistency between G_OPT_V_INPUT and G_OPT_R_INPUT
Martin Landa landa.martin at gmail.com
Wed May 13 02:08:11 PDT 2015
2015-05-13 8:03 GMT+02:00 Pietro <peter.zamb at gmail.com>:
> #% description: Name of vector map with interested segments of rivers
<- label
> As you can see the description of the parameter add the default
> description set in G_OPT_V_INPUT and in a new line the description
> added manually in the definition of the module parameters. Instead the
> G_OPT_R_INPUT shows only the description set manually.
right, G_OPT_V_INPUT has defined both label and description [1]. This
the source of inconsistency. There are more standard options which
defines both label and description.
Martin
[1] http://grass.osgeo.org/programming7/parser__standard__options_8c_source.html#l00442
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
