[GRASS-dev] [GRASS GIS] #2676: r.neighbors on large rasters
GRASS GIS trac at osgeo.org
Wed May 13 07:18:09 PDT 2015
 Reporter:  dnewcomb                   |      Owner:  grass-dev@…
     Type:  enhancement                |     Status:  new
 Priority:  normal                     |  Milestone:  7.0.1
Component:  Default                    |    Version:  svn-trunk
 Keywords:  r.neighbors large rasters  |        CPU:  x86-64
 Platform:  Linux                      |
 running r.neighbors --o --verbose input=naip_change
 output=naip_change_average method=average size=29
 The input raster is  ( r.info output)
 Total Cells:  365659744068
 Starts and shows 0% complete, then crashes with segmentation fault.
 linux top program  shows process using 1.5 GB RAM before crash
 Using
 grass-7.0.svn_src_snapshot_2015_05_02
 In main.c , line 139 I see :
 int i , n;
   I assume that this means that r.neighbors is limited to rasters with the
 number of cells in the 32 bit integer range?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2676>
