[GRASS-dev] [GRASS-SVN] r65249 - grass/trunk/raster/r.topidx
Vaclav Petras wenzeslaus at gmail.com
Fri May 15 12:25:36 PDT 2015
On Fri, May 15, 2015 at 2:04 PM, Huidae Cho <grass4u at gmail.com> wrote:
> Hi, Thanks for pointing me to the script. I just manually adjusted
several lines to make them 80 columns. Based on the script, it looks like
couple options were dropped (-ts8, -ut) and new ones were added (-npro,
--no-tabs).
-npro was there before. It prevents loading the user settings or something
like that.
For the rest, see the relevant change set:
https://trac.osgeo.org/grass/changeset/64658
> On Fri, May 15, 2015 at 1:22 PM, Vaclav Petras <wenzeslaus at gmail.com>
wrote:
>> Hi, I see that you are making the indent in a file consistent but I just
wanted to make sure you know that I recently updated the script
./tools/grass_indent.sh.
>> On Fri, May 15, 2015 at 11:42 AM, <svn_grass at osgeo.org> wrote:
>>> Author: hcho
>>> Date: 2015-05-15 08:42:52 -0700 (Fri, 15 May 2015)
>>> New Revision: 65249
>>> Modified:
>>>    grass/trunk/raster/r.topidx/main.c
>>>    grass/trunk/raster/r.topidx/topidx.c
>>> Log:
>>> r.topidx: indent
>>> grass-commit mailing list
>>> grass-commit at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-commit
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150515/f7432ec6/attachment.html>
