[GRASS-dev] t.connect test for rasters takes over 3 hours to execute
Sören Gebbert soerengebbert at googlemail.com
Mon May 18 04:50:18 PDT 2015
Hi Vaclav,
Many thanks for this report. This is really strange, i never run in
such problems and cannot reproduce this (3h execution time) on AMD
Phenom II with Ubuntu 12.04, AMD FX8350 with Ubuntu 14.04 and google
cloud compute engine with Ubuntu 14.04 and debian.
However, on my machines (AMD Phenom II with Ubuntu 12.04, AMD FX8350
with Ubuntu 14.04 ) the g.remove process segfaults most of the time
when called from PyGRASS?? And i have no idea why.
I will try to investigate this on different computers in my Institute.
Best regards
Soeren
2015-05-11 15:52 GMT+02:00 Vaclav Petras <wenzeslaus at gmail.com>:
> Hi,
> when I run t.connect test test_distr_tgis_db_raster.py [0] in Piemonte
> Location [1], it takes 3.5 hours to complete [2]. This is happening
> constantly for a long time already [3]. There is nothing in the outputs
> which would indicate anything like this. Any ideas?
> In case you wonder how different data influence the time, then you can see
> run in NC SPM Location [4] and in an empty XY Location [5]. Also, similar
> tests for 3D raster and vector data are fine [6, 7].
> Is somebody able to reproduce that behavior or determine why it is
> happening?
> Thanks,
> Vaclav
> [0]
> http://trac.osgeo.org/grass/browser/grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_raster.py
> [1] http://grass.osgeo.org/download/sample-data/
> [2]
> http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2015-05-11-07-00/report_for_piemonte_utm32_wgs84_grass7_stdmaps/temporal/t.connect/test_distr_tgis_db_raster/index.html
> [3]
> http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2014-10-02-07-00/report_for_piemonte_utm32_wgs84_grass7_stdmaps/temporal/t.connect/test_distr_tgis_db_raster/index.html
> [4]
> http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2015-05-11-07-00/report_for_nc_spm_08_grass7_nc/temporal/t.connect/test_distr_tgis_db_raster/index.html
> [5]
> http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2015-05-11-07-00/report_for_empty_xy_all/temporal/t.connect/test_distr_tgis_db_raster/index.html
> [6]
> http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2015-05-11-07-00/report_for_piemonte_utm32_wgs84_grass7_stdmaps/temporal/t.connect/test_distr_tgis_db_raster3d/index.html
> [7]
> http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2015-05-11-07-00/report_for_piemonte_utm32_wgs84_grass7_stdmaps/temporal/t.connect/test_distr_tgis_db_vector/index.html
