[GRASS-dev] r.proj produces null map
Margherita Di Leo diregola at gmail.com
Mon May 18 08:16:28 PDT 2015
on G7, I made several tentatives trying to reproject raster maps using
r.proj, it doesn't yield error but the map is completely empty (null). I
made several tentatives on several maps, then also exported and reprojected
with gdalwarp, to test if the problem was related to the data. Can someone
reproduce this, before i open a ticket.
Thank you
Best regards,
Dr. Margherita DI LEO
Scientific / technical project officer
European Commission - DG JRC
Institute for Environment and Sustainability (IES)
Via Fermi, 2749
I-21027 Ispra (VA) - Italy - TP 261
Tel. +39 0332 78 3600
margherita.di-leo at jrc.ec.europa.eu
Disclaimer: The views expressed are purely those of the writer and may not
in any circumstance be regarded as stating an official position of the
European Commission.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150518/3f0e6b13/attachment.html>
