[GRASS-dev] [GRASS GIS] #2671: r.surf.idw won't make interpolation
GRASS GIS trac at osgeo.org
Mon May 18 23:41:58 PDT 2015
  Reporter:  kuszinger  |      Owner:  grass-dev@…
      Type:  defect     |     Status:  new
  Priority:  normal     |  Milestone:  7.1.0
 Component:  Raster     |    Version:  svn-trunk
Resolution:             |   Keywords:  interpolation, r.surf.idw
       CPU:  x86-64     |   Platform:  Linux
Comment (by neteler):
 The indicated test is now performed as follows:
 # GRASS 7.1.svn (nc_spm_08_grass7)
 g.region raster=elevation at PERMANENT -p
 r.random -z --overwrite input=elevation at PERMANENT npoints=100000
 raster=elev_sparse
 r.surf.idw --overwrite input=elev_sparse output=elev_sparse_idw npoints=7
 ERROR: This module currently only works for integer (CELL) maps
 So, no result should be expected unless #2672 is solved.
 Replying to [comment:6 annakrat]:
 > I think I fixed it in r65214. Null values were not identified correctly.
 I still don't understand why 64 version actually works.
 Backported in r65261.
 > By the way, r.surf.idw works only with integer rasters. But this is for
 a different ticket.
 Closing here, continuing in ticket #2672
Ticket URL: <http://trac.osgeo.org/grass/ticket/2671#comment:7>
