[GRASS-dev] [GRASS GIS] #2680: d.mon: input file has incorrect dimensions
GRASS GIS trac at osgeo.org
Fri May 22 04:32:29 PDT 2015
  Reporter:  annakrat     |      Owner:  martinl
      Type:  defect       |     Status:  assigned
  Priority:  normal       |  Milestone:  7.1.0
 Component:  Display      |    Version:  svn-trunk
Resolution:               |   Keywords:  d.mon
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by martinl):
 Replying to [comment:2 martinl]:
 > this issue should be fixed in r65303.
 > > 2. On Windows, this is even more interesting. I open wx0 monitor, run
 for example d.rast, so far good, but the second d command fails (but the
 window is still the same as when it opened):
 > Let's wait for next build if it helps.
 It seems to fix both issue.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2680#comment:3>
