[GRASS-dev] [GRASS GIS] #2796: PostgreSQL database connections fail in some parts of the gui
GRASS GIS trac at osgeo.org
Wed Nov 11 05:42:43 PST 2015
 Reporter:  harrik      |      Owner:  grass-dev@…
     Type:  defect      |     Status:  new
 Priority:  normal      |  Milestone:
Component:  Database    |    Version:  7.0.1
 Keywords:  PostgreSQL  |        CPU:  x86-64
 Platform:  Linux       |
 Hi!
 I tested the 7.0.2RC2, and noticed, that the database connections for my
 vectors from 6.4 did not work anymore with the new GUI. The attribute
 table is shown ok, but the display of labels and editing of attributes in
 the digitizer do not work: if I try to display labels for the vector
 features, the map stays empty, and neither the features nor labels are
 shown; without labels, the features are shown fine. The digitizer opens
 fine, but trying to see the attributes, or adding attributes to a newly
 drawn feature fail with no clear error messages.
 From what I gathered, it seems that the setting for the "schema" in the
 database is not taken into account, for example the connection for vector
 "struct" used to be to the postgres table "grass.struct", where "grass" is
 the schema set up with db.connect. However, this version of GRASS seems to
 try to access the table using just the name "struct", which will lead to
 error.
 Best,
 Harri K.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2796>
