[GRASS-dev] [GRASS-SVN] r66772 - in grass/trunk: db/drivers db/drivers/dbf db/drivers/mysql db/drivers/odbc db/drivers/ogr db/drivers/postgres db/drivers/sqlite lib/db/dbmi_driver lib/db/stubs
Huidae Cho grass4u at gmail.com
Wed Nov 11 11:41:22 PST 2015
I can also confirm this. I had to copy dbstubs.h to dist.../include/grass,
but I'm not sure what brought those changes in the above revision. If we
have to keep this revision, adding dbstubs.h in include/ should address
this issue...
On Wed, Nov 11, 2015 at 11:54 AM, Vaclav Petras <wenzeslaus at gmail.com>
wrote:
> On Wed, Nov 11, 2015 at 11:14 AM, Martin Landa <landa.martin at gmail.com>
> wrote:
> > 2015-11-11 16:52 GMT+01:00 Martin Landa <landa.martin at gmail.com>:
> > > fyi, it seems that it broke travis builds [1]. Ma
> > > add_col.c:2:27: fatal error: grass/dbstubs.h: No such file or directory
> > > compilation terminated.
> > > [1]
> https://s3.amazonaws.com/archive.travis-ci.org/jobs/90543352/log.txt
> > it's also broken on my pc, can anybody confirm it?
> I can confirm it but I was not able to figure out what is wrong.
> https://lists.osgeo.org/pipermail/grass-dev/2015-November/077266.html
> https://lists.osgeo.org/pipermail/grass-dev/2015-November/077278.html
> > execute.c:2:27: fatal error: grass/dbstubs.h: No such file or directory
> > ../../../include/Make/Compile.make:32: recipe for target
> > 'OBJ.x86_64-unknown-linux-gnu/execute.o' failed
> > make[4]: *** [OBJ.x86_64-unknown-linux-gnu/execute.o] Error 1
> > make[4]: Leaving directory '/opt/src/grass_trunk/lib/db/stubs'
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151111/06cede83/attachment.html>
