[GRASS-dev] proposal for g.search module
Jachym Cepicky jachym.cepicky at gmail.com
Sat Nov 28 08:27:03 PST 2015
OK guys,
if nobody protests, I'll prepare basic framework for g.search.* modules and
let you know, once it's about to be ready
Jachym
so 28. 11. 2015 v 15:52 odesílatel Yann <ychemin at gmail.com> napsal:
> +1 awesomeness
> +1 for trunk
> On 27/11/2015 17:12, Vaclav Petras wrote:
> > On Fri, Nov 27, 2015 at 10:51 AM, Jachym Cepicky <
> jachym.cepicky at gmail.com>
> > wrote:
> >> Hi all,
> >> I've tried to implement command line alternative to module search based
> on
> >> keywords, which is available in the gui - it's called g.search
> >> Any chance, you might find this useful ? Any comment to the source code
> >> and outputs?
> >> https://github.com/jachym/g.search
> > I think it is awesome:
> > $ g.extension extension=g.search url=https://github.com/jachym/g.search
> > $ g.search MLC
> > i.gensig
> >      Description: Generates statistics for i.maxlik from raster map.
> >      Keywords: imagery,classification,supervised classification,Maximum
> > Likelihood Classification,MLC,signatures
> > i.maxlik
> >      Description: Classifies the cell spectral reflectances in imagery
> data.
> > Classification is based on the spectral signature information generated
> by
> > either i.cluster, g.gui.iclass, or i.gensig.
> >      Keywords: imagery,classification,Maximum Likelihood
> Classification,MLC
> > The code is minimalistic, so the duplication with GUI code is minimal or
> > none.
> > I suggest to put it to trunk, but to consider the name first. g.search
> > sounds good but does it search modules or maps or both? Are the maps a
> > possible extension of the current functionality?
> > Vaclav
> > grass-dev mailing list
> > grass-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/grass-dev
> Yann Chemin
> Address: 3 Toul Melin, 56400 Plumergat
> Mobile: +33 (0)7 83 85 52 34
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151128/f913e4e1/attachment.html>
