[GRASS-dev] I've tripled GRASS's I/O speed
Seth Price seth at planet.com
Mon Oct 5 12:21:45 PDT 2015
Hi, I've spent the last two or three hours trying to get GRASS' unit tests
running. With a fresh source tree, the best I can get is ~9% of the tests
passing:
seths-mbp:grass-7.1.svn_src_snapshot_2015_09_19 sprice$ grass71 --text
../nc_spm_08_grass7/PERMANENT/
GRASS 7.1.svn
(nc_spm_08_grass7):/usr/local/grass/grass-7.1.svn_src_snapshot_2015_09_19 >
python -m grass.gunittest.main --location
/usr/local/grass/nc_spm_08_grass7/ --location-type nc
test_g_list from ./general/g.list failed (1 test failed)
test_g_remove from ./general/g.remove failed (2 tests failed)
test_overwrite from ./general/g.rename failed (3 tests failed)
test_vto3d from ./vector/v.to.3d failed (1 test failed)
test_vwhat_layers from ./vector/v.what failed (1 test failed)
test_vwhat_ncspm from ./vector/v.what failed (4 tests failed)
Executed 127 test files in 0:00:55.959398.
>From them 12 files (9%) were successful and 115 files (91%) failed.
GRASS 7.1.svn
I'd really like to work on these unit tests. Any ideas as to where I'm
going wrong? I feel like I've exhausted the various knowledge bases
available online.
Thanks,
Seth
On Fri, Oct 2, 2015 at 11:25 AM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> On Fri, Oct 2, 2015 at 12:49 PM, Seth Price <seth at planet.com> wrote:
>> ..by adding the option of a few different compression schemes, including
>> LZ4. I've had the ticket open for a week now with no responses. I'd love to
>> get it incorporated into trunk. For more info, see here:
>> https://trac.osgeo.org/grass/ticket/2750
> Hi,
> thanks for the reminder. This looks really good. Can you provide a test
> which would do a trivial operation (like the benchmark in the ticket)
> ideally using Python and gunittest [1]? Please, let me know if you don't
> know where to start.
> Vaclav
> [1]
> https://grass.osgeo.org/grass71/manuals/libpython/gunittest_testing.html
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151005/6cfe8da5/attachment.html>
