[GRASS-dev] I've tripled GRASS's I/O speed
Seth Price seth at planet.com
Mon Oct 5 22:42:42 PDT 2015
Sorry for derailing my own thread, but here we go again...
I'm having a hard time reproducing anything with the unit tests. There
seems to be some state that exists between unit test runs. I ran it with my
updated code, and I got 30% failed. Then I ran the new code with the tests,
and I'm getting 30% failed. So I deleted the basic location directory and
re-decompressed it. Now I'm getting 31% failed in both directories.
Using these commands, as shown above, resulted in 21% failed. I'm running
`make && sudo make install` when I switch directories. Then I delete &
refresh the location files. Then I run the unit tests as `python -m
grass.gunittest.main --location nc_basic_spm_grass7 --location-type nc`.
What's wrong with my test procedure?
On Mon, Oct 5, 2015 at 3:57 PM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> On Mon, Oct 5, 2015 at 6:41 PM, Seth Price <seth at planet.com> wrote:
>> The tests are without my changes on 64 bit Mac v10.10.5, Mac Pro with 64
>> GB of RAM.
> Good, I hope now you are ready to run tests with your changes as well.
> BTW, great that you run tests on Mac!
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151005/b9837ae2/attachment.html>
