[GRASS-dev] GRASS will not not find laslib
Anna Petrášová kratochanna at gmail.com
Thu Oct 8 15:07:14 PDT 2015
On Thu, Oct 8, 2015 at 5:24 PM, Michael Barton <Michael.Barton at asu.edu>
wrote:
> With a lot of effort and some help, I've rebuilt liblas with new GDAL. Now
> GRASS will not find liblas with the same configuration script that I've
> used before. Here it is:
Was there some specific trick that you could share?
> ./configure --with-macosx-sdk=/Developer/SDKs/MacOSX10.7.sdk
> --with-freetype
> --with-freetype-includes="/Library/Frameworks/FreeType.framework/unix/include/freetype2 /Library/Frameworks/FreeType.framework/unix/include"
> --with-freetype-libs=/Library/Frameworks/FreeType.framework/unix/lib
> --with-gdal=/Library/Frameworks/GDAL.framework/Programs/gdal-config
> --with-proj
> --with-proj-includes=/Library/Frameworks/PROJ.framework/unix/include
> --with-proj-libs=/Library/Frameworks/PROJ.framework/unix/lib
> --with-proj-share=/Library/Frameworks/PROJ.framework/Resources/proj
> --with-geos=/Library/Frameworks/GEOS.framework/Versions/3/unix/bin/geos-config
> --with-jpeg-includes=/Library/Frameworks/UnixImageIO.framework/unix/include
> --with-jpeg-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib
> --with-png-includes=/Library/Frameworks/UnixImageIO.framework/unix/include
> --with-png-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib
> --with-tiff-includes=/Library/Frameworks/UnixImageIO.framework/unix/include
> --with-tiff-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib
> --with-cairo
> --with-cairo-includes="/Library/Frameworks/cairo.framework/unix/include/cairo /Library/Frameworks/cairo.framework/unix/include"
> --with-cairo-libs=/Library/Frameworks/cairo.framework/unix/lib
> --with-cairo-ldflags="-lcairo" --without-postgres --without-mysql
> --with-sqlite
> --with-sqlite-libs=/Library/Frameworks/SQLite3.framework/unix/lib
> --with-sqlite-includes=/Library/Frameworks/SQLite3.framework/unix/include
> --with-fftw-includes=/Library/Frameworks/FFTW3.framework/unix/include
> --with-fftw-libs=/Library/Frameworks/FFTW3.framework/unix/lib --with-x
> --with-cxx --with-opengl=aqua --without-readline --prefix=/Applications
> --enable-macosx-app --with-python
> --with-wxwidgets=/usr/local/lib/wxPython-unicode-2.8.12.1/bin/wx-config
> --with-tcltk-includes="/Library/Frameworks/Tcl.framework/Headers
> /Library/Frameworks/Tk.framework/Headers
> /Library/Frameworks/Tk.framework/PrivateHeaders"
> --with-tcltk-libs="/usr/local/tcltk_active/lib" --with-macosx-archs="i386
> x86_64" --with-liblas="/usr/local/bin/liblas-config" --with-opencl
> --with-nls --with-libs=/usr/local/lib  --with-includes=/usr/local/include
> FWIW, here is the uninformative error. Any thoughts???
There should be a log file from the configuration with more details, not
sure what's its name though.
> checking for liblas-config... /usr/local/bin/liblas-config
> configure: error: *** Unable to locate libLAS library.
> (yes liblas-config is exactly where I say it is)
> Michael
> ____________________
> C. Michael Barton
> Director, Center for Social Dynamics & Complexity
> Professor of Anthropology, School of Human Evolution & Social Change
> Head, Graduate Faculty in Complex Adaptive Systems Science
> Arizona State University
> voice:  480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
> fax: 480-965-7671 (SHESC),  480-727-0709 (CSDC)
> www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151008/7b645b27/attachment.html>
