[GRASS-dev] Using a dynamic text in module header for parser
Anna Petrášová kratochanna at gmail.com
Tue Oct 13 06:51:25 PDT 2015
you can look how Layer manager launches scripts:
https://trac.osgeo.org/grass/browser/grass/trunk/gui/wxpython/lmgr/frame.py#L841,
I think it requires setting the GRASS_ADDON_PATH
I remember this problem, maybe it's in parser. There might be a ticket
already, but I am not sure. If you can't find anything related, please
create a ticket.
On Tue, Oct 13, 2015 at 9:33 AM, Michel Wortmann <wortmann at pik-potsdam.de>
wrote:
> Hi Stefan,
> I have been meaning to implement something like this too and got your
> example to work with the additional step of setting the environment
> variable GRASS_ADDON_PATH (and under unix setting the permissions). Here is
> my example just parsing the first mapset it finds:
> import os, tempfile, stat
> import grass.script as grass
> module = 'subbasins.py'
> if __name__=='__main__':
>     answer = grass.mapsets(search_path = True)
>     available_mapsets = grass.mapsets()
>     script=file(module,'r').read()
>     with tempfile.NamedTemporaryFile(delete = False) as s:
>         s.write('''#!/usr/bin/env python
> # -*- coding: utf-8 -*-
> {script}
> #%Option
> #% key:{option}
> #%end
> '''.format(script=script,option=available_mapsets[0].lower()))
>     startcmd = 'python '+s.name
>     # set env variable
>     aoev='GRASS_ADDON_PATH'
>     tmpdir = os.path.basename(s.name)
>     if aoev in os.environ:
>         os.environ[aoev]=[tmpdir]+os.environ[aoev]
>     else:
>     # set permissions
>     os.chmod(s.name, os.stat(s.name).st_mode | stat.S_IEXEC)
>     # start module
>     os.system(startcmd)
>     os.remove(s.name)
> Let me know if this works under Windows too.
> Michel
> On 10/12/2015 12:55 PM, Blumentrath, Stefan wrote:
> Hi again,
> Now I found out that the parser section in the inner python script was not
> formated properly.
> However, when I now call the inner script with ‘--ui’ I get an error:
> Unable to fetch interface description for command ‘tmpjksdfjiol’
> Details:
> Try to set up GRASS_ADDON_PATH or GRASS_ADDON_BASE variable.
> It was neither possible to run the script using grass.run_command() (on
> Windows).
> Cheers
> Stefan
> *From:* grass-dev [mailto:grass-dev-bounces at lists.osgeo.org
> <grass-dev-bounces at lists.osgeo.org>] *On Behalf Of *Blumentrath, Stefan
> *Sent:* 12. oktober 2015 11:36
> *To:* GRASS developers list (grass-dev at lists.osgeo.org)
> <grass-dev at lists.osgeo.org> <grass-dev at lists.osgeo.org>
> *Subject:* [GRASS-dev] Using a dynamic text in module header for parser
> Hi,
> I would like to fill:
> #% options:
> and
> #% answer
> in a parser option for a python script dynamically.  In particular I want
> to have tickboxes for available mapsets in the module GUI…
> Meaning something like this  (but less complex / not interactive):
> http://permalink.gmane.org/gmane.comp.gis.grass.gui/667
> My amateur programming skills do unfortunately not allow me to really
> understand how to accomplish what Glynn describes in the post above…
> I tried to generate and run a temporary python script from within my
> script like this:
> def main():
>     available_mapsets = str(grass.mapsets())
>         s.write('''    #!/usr/bin/env python
> # Here comes the full module with header for the parser
> #% options: ''' + str(','.join(available_mapsets))
>     startcmd = 'python ' + s.name
>     os.system(startcmd)
>     os.remove(s.name)
> But that way the GUI never starts, when I call the outer script from GRASS
> and it seems that option never get parsed…
> Any hints how to proceed?
> Thanks for helping in advance.
> Stefan
> grass-dev mailing listgrass-dev at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151013/201df24c/attachment-0001.html>
