[GRASS-dev] [GRASS GIS] #2558: The 'Profile Surfae Map' tool does not function.
GRASS GIS trac at osgeo.org
Fri Oct 23 06:25:56 PDT 2015
  Reporter:  humu2015     |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  critical     |  Milestone:  6.4.6
 Component:  wxGUI        |    Version:  unspecified
Resolution:               |   Keywords:
       CPU:  Unspecified  |   Platform:  Linux
Comment (by annakrat):
 Replying to [comment:6 mlennert]:
 > Is there really no other solution than to wait for the next release ?
 This makes many very nice GUI features completely unusable.
 The only solution I can see (beside rewriting it using matplotlib) is to
 copy and integrate the particular code with the fix in GRASS. Licence
 should be OK I hope. I can try to do that, but I fear I run into problems
 with different versions of wxPython on different computers. Do we know for
 which versions the code has this bug?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2558#comment:7>
