[GRASS-dev] v.rast.stats: ERROR: Input window changed while maps are open for read.
Helmut Kudrnovsky hellik at web.de
Sat Oct 24 11:28:01 PDT 2015
Helmut Kudrnovsky wrote
> hi,
> by testing the manual example of v.rast.stats, I get following error:
> v.rast.stats --verbose map=myzipcodes_wake at gbiftest
> raster=elevation at PERMANENT column_prefix=elev
> method=minimum,maximum,average,stddev,percentile
> Adding columns '['elev_minimum DOUBLE PRECISION', 'elev_maximum DOUBLE
> PRECISION', 'elev_average DOUBLE PRECISION', 'elev_stddev DOUBLE
> PRECISION', 'elev_percentile_90 DOUBLE PRECISION']'
> Adding column
> <elev_minimum>
>  to the table
> Adding column
> <elev_maximum>
>  to the table
> Adding column
> <elev_average>
>  to the table
> Adding column
> <elev_stddev>
>  to the table
> Adding column
> <elev_percentile_90>
>  to the table
> Processing data (13 categories)...
> ERROR: Input window changed while maps are open for read. Map name
> <myzipcodes_wake_8088.0>
> Updating the database ...
> Statistics calculated from raster map <elevation at PERMANENT> and
> uploaded to attribute table of vector map
> <myzipcodes_wake>
> DEBUG=3 output
> <http://osgeo-org.1560.x6.nabble.com/file/n5232313/grass_cmd_output.txt>
> tested with
> System Info
> GRASS version: 7.1.svn
> GRASS SVN revision: 66569
> Build date: 2015-10-22
> Build platform: i686-pc-mingw32
> GDAL: 1.11.3
> PROJ.4: 4.8.0
> GEOS: 3.5.0
> SQLite: 3.7.17
> Python: 2.7.4
> wxPython: 2.8.12.1
> Platform: Windows-7-6.1.7601-SP1 (OSGeo4W)
also tested with
GRASS Version: 7.1.svn
GRASS SVN revision: 66581
Build date: 2015-10-23
GDAL: 1.11.3
PROJ.4: 4.8.0
GEOS: 3.5.0
SQLite: 3.7.17
Python: 2.7.4
wxPython: 2.8.12.1
Platform: Windows-Vista-6.0.6002-SP2 (OSGeo4W)
same error:
<myzipcodes_wake_1180.0>
but it is not in
GRASS Version: 7.0.2RC1
GRASS SVN Revision: 66536
open a ticket
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/v-rast-stats-ERROR-Input-window-changed-while-maps-are-open-for-read-tp5232313p5232370.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
