[GRASS-dev] compiling GRASS fails at configure, unable to locate GDAL library
Paulo van Breugel p.vanbreugel at gmail.com
Thu Oct 29 02:49:27 PDT 2015
Hi, I am trying to make a fresh install of GRASS master, something I do
routinely about every week (on Ubuntu 14.04). This time however, when
running .configure (see below), I get the error message that the gdal
library cannot be found. However, it is there, and in fact nothing
changed since the last successful install of GRASS. Any ideas?
> ./configure --prefix=/usr/local/grass7 --enable-64bit
> --with-libs=/lib64 --with-sqlite --with-odbc --with-cairo --with-geos
> --with-cxx=yes --with-gdal=/usr/local/bin/ --with-python=yes
> --with-wxwidgets=/usr/bin/wx-config --with-readline --with-freetype
> --with-freetype-includes=/usr/include/freetype2 --enable-largefile
> --with-motif --with-motif-includes=/usr/include
> --with-proj-share=/usr/share/proj --with-postgres
> --with-postgres-libs=/usr/include/postgresql/libpq
> --with-postgres-includes=/usr/include/postgresql --with-lapack
> --with-blas --with-opencl --with-pthread
Gives me
> checking for gdal-config... /usr/local/bin/gdal-config
> configure: error: *** Unable to locate GDAL library.
