[GRASS-dev] possible error in WIKI could cause data corruption
Michael Barton Michael.Barton at asu.edu
Sat Sep 5 16:10:57 PDT 2015
So I decided to try this with 7.0 and looked again at the mapset. It turns out that the folder is there but not the sqlite.db.
So perhaps we need to add to the WIKI that you might need to create the sqlite.db
However, when I tried to create the database, it doesn’t seem to work.
db.createdb driver=sqlite database=$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db
dbmi: db_create_database() not implemented
No error. Just no database.
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Head, Graduate Faculty in Complex Adaptive Systems Science
Arizona State University
voice:  480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax: 480-965-7671 (SHESC),  480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
> On Sep 5, 2015, at 11:26 AM, Markus Neteler <neteler at osgeo.org> wrote:
> On Sat, Sep 5, 2015 at 7:51 PM, Michael Barton <Michael.Barton at asu.edu> wrote:
>> I don’t know if this is bad advice in the GRASS WIKI or a bug in a GRASS
>> database module. I have some vector files that were somehow imported into a
>> dbf DBMS last year. I wanted to switch them all to sqlite. The GRASS WIKI
>> advises…
>> Convert automatically all GRASS 6 vector maps to GRASS 7 (including
>> attribute transfer from DBF to SQLite)
> https://grasswiki.osgeo.org/wiki/Convert_all_GRASS_6_vector_maps_to_GRASS_7
>> The vectors already had GRASS 7 topology, but I ran v.rebuild.all just to be
>> sure. No problem.
>> db.connect -d ran with no problem
>> But v.db.reconnect.all -cd did not create tables in the sqlite database
> But the sqlite file is there?
>> and corrupted the existing connection of the first table it hit. Fortunately, I
>> made a backup of the mapset before I started this.
> Perhaps a problem on Mac?
> This is strange - I have converted so many mapsets like that ..., even
> with lots of vector maps inside.
> The wiki page is there for a long time, I didn't see such reports so far.
>> GRASS 7.1.svn (Spain_fieldwork_medlands_ERTS89_Z30):~ > v.db.reconnect.all
>> -cd
>> Reconnecting vector map <catastro at surveyboundaries> (1 of 9)...
>> Copying table <catastro> to target database...
>> Traceback (most recent call last):
>>  File
>> "/Applications/GRASS/GRASS-7.1.app/Contents/MacOS/scripts/db.droptable",
>> line 99, in <module>
>>    main()
>>  File
>> line 77, in main
>>    used = grass.db.db_table_in_vector(table)
>>  File
>> "/Applications/GRASS/GRASS-7.1.app/Contents/MacOS/etc/python/grass/script/db.py",
>> line 184, in db_table_in_vector
>>    from vector import vector_db
>> ImportError: No module named vector
> Maybe something got broken in GRASS 7.1?
> I would definitely use 7.0 for such operations.
> Markus
>> ERROR: Unable to drop table <catastro>
>> Michael
>> C. Michael Barton
