[GRASS-dev] r.resample.rst behavior does not match manual
Markus Neteler neteler at osgeo.org
Thu Sep 10 07:56:17 PDT 2015
On Sun, Aug 30, 2015 at 9:54 AM, Blumentrath, Stefan
<Stefan.Blumentrath at nina.no> wrote:
> Hi Michael,
> The second sentence you cite from the manual seems indeed a bit imprecise.
> It should probably say something like:
> “The extent of all resulting raster maps is taken from the settings of the
> current region (which may be different from the extent of the input raster
> map). The resolution of the current region however has to follow cleanly the
> resolution of the input map”
I have added a modified version of above suggestion to the manual in
https://trac.osgeo.org/grass/changeset/66163
Further improvements are always welcome.
Markus
