[GRASS-dev] [GRASS GIS] #2738: sigfile problem with i.gensigset
GRASS GIS trac at osgeo.org
Thu Sep 10 08:14:31 PDT 2015
 Reporter:  carminem  |      Owner:  grass-dev@…
     Type:  defect    |     Status:  new
 Priority:  major     |  Milestone:
Component:  Imagery   |    Version:  7.0.1
 Keywords:            |        CPU:  x86-64
 Platform:  Linux     |
 When I launch i.gensigset I receive this error as popup:
 'ascii' codec can't decode byte 0xc3 in position 10: ordinal not in
 range(128)
 Then I compile all the field required from the form but grass is not able
 to produce the sigfile, the only two line written are reported:
 title: Rasterized vector map from labels[[BR]]
 nbands: 47
 I use grass 7.0.1 in ubuntu 14.04.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2738>
