[GRASS-dev] [GRASS GIS] #2448: Fontconfig error with cairo on Windows
Helmut Kudrnovsky
hellik at web.de
Fri Sep 11 00:28:16 PDT 2015
Paul Kelly wrote
>> a feasable way may be:
>> - another flag e.g. to write fontcap file to %APPDATA%GRASS7 where
>> already
>> the addons are stored
>> - all the modules which are working with fonts seems to search for the
>> fontcap file in $GISBASE/etc; adding a second search path (e.g.
>> %APPDATA%GRASS7) to these modules if the file is not available in
>> $GISBASE/etc
> Similar to this, I was just going to suggest why don't you set the
> GRASS_FONT_CAP environment variable to a path that *is* writable. Then
> g.mkfontcap, and all the modules that use the fontcap, will simply use
> that instead of the fontcap in $GISBASE/etc. This mechanism is explicitly
> designed for the situation where a user doesn't have write access to
> $GIBASE/etc and needs to override the system fontcap file.
> However, I don't think this is a good solution if the installation is
> required to be available to other users on the same Windows machine as the
> writable path will likely only be available to that user, if I understand
> correctly.
> Paul
thanks!
I wasn't aware of GRASS_FONT_CAP environment variable. [1]
GRASS_FONT_CAP
[g.mkfontcap, d.font, display drivers]
specifies an alternative location (to $GISBASE/etc/fontcap) for the font
configuration file.
using this variable may ease a lot this issue.
in Windows there is C:\Users\All Users availabe, where application stores
files etc which should be available for all users.
[1] https://grass.osgeo.org/grass70/manuals/variables.html
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/Re-GRASS-GIS-2448-Fontconfig-error-with-cairo-on-Windows-tp5221935p5223702.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
