[GRASS-dev] addon mismatch
Paulo van Breugel p.vanbreugel at gmail.com
Fri Sep 11 14:17:42 PDT 2015
On 11-09-15 19:44, Vaclav Petras wrote:
> On Fri, Sep 11, 2015 at 1:37 PM, Paulo van Breugel
> <p.vanbreugel at gmail.com <mailto:p.vanbreugel at gmail.com>> wrote:
>     On 11-09-15 19:31, Vaclav Petras wrote:
>>     On Fri, Sep 11, 2015 at 1:13 PM, Paulo van Breugel
>>         PS: no idea what "WARNING: No addons metadata available. Addons
>>         metadata file not updated." means
>>         No clue either, but maybe the reason it doesn't show in the
>>         g.extension GUI?
>>     Well, I did pretty heavy changes in trunk's g.extension but I was
>>     not getting this warning. It means that it can't find a
>>     particular XML on the server. Does this happen for other addons
>>     or just r.biodiversity?
>     It seems not, I just tried to (re) install two others (r.bioclim
>     and r.mess) and I did not get such warning
> I don't know if the server-side XMLs are generated for 71 or just 70
> but probably they are.
Yes, that is it. When using the
https://svn.osgeo.org/grass/grass-addons/grass7/ address, things work as
expected, the addon appears in the list and no error message. Would it
be possible to make this work for v71 as well?
> Then I can also see that the addons page [1] data in the bottom is
> some completely old one (Út srp 18 means Tuesday, August 18). Since it
> is happening just for the new addon, it might be just because of some
> delay in generating all server side things; I always have the feeling
> that there is some delay, although it should be just 24 max.
> [1] https://grass.osgeo.org/grass70/manuals/addons/
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150911/f1d2db50/attachment.html>
