[GRASS-dev] r.in.lidar not running in Mac binaries for 7.1
Vaclav Petras wenzeslaus at gmail.com
Tue Sep 15 18:02:25 PDT 2015
[Was: Re: [GRASS-dev] New Mac binaries uploaded]
Hi Michael,
On Mon, Aug 24, 2015 at 11:45 PM, Michael Barton <Michael.Barton at asu.edu>
wrote:
> That would be wonderful. I sort of got that impression too. But will the
> GRASS lidar tools be able to use LASlib instead of Liblas?
the binary in Dropbox has lasinfo et al. from LAStools. However, r.in.lidar
doesn't work (2 different computers). Does it work for you? Running
r.in.lidar or v.in.lidar --help and says
dyld: Library not loaded: /usr/local/lib/liblas.2.2.0.dylib
As I said earlier, GRASS is made to dynamically link with libLAS. In case
the API of LAStools library is the same, there might be a way to change the
GRASS configuration and makefiles or the ones for LAStools, so that GRASS
can compile with LAStools statically but I don't know the way.
Currently with LAStools compiled with GRASS on Mac, you can use the tools
in command line but it's useless for GRASS modules, namely r|v.in.lidar.
Thanks,
Vaclav
PS: Although I'm working on migration to PDAL [1], it will take some time
before it gets even to 7.1 (trunk), not mentioning 7.0. So, the libLAS
library is still needed.
[1] https://trac.osgeo.org/grass/ticket/2732
> On Aug 24, 2015, at 8:40 PM, William Kyngesburye <woklist at kyngchaos.com>
> wrote:
> > I looked at LAS this spring.  From what I found, libLAS is superceded by
> LASlib, found in LAStools.  laslib and some of the tools are still
> opensource, but other tools are not.
> > Laslib does not have a configure, it's a simple makefile that needs a
> little tweaking for OS X.  And there appears to be no dependence on BOOST
> or Geotiff, or anything else.
> > For laslib, all I needed to do was edit laslib/src/makefile and change
> these lines:
> > COPTS     = -Os -Wall -Wno-deprecated -DNDEBUG -DUNORDERED -arch x86_64
> -isysroot /Developer/SDKs/MacOSX10.7.sdk
> > COMPILER  = clang++
> > And in the liblas.a target, add a line after the cp line (tha's a tab at
> the start):
> >       ranlib ../lib/$@
> > Also delete the precompiled Windows lib in laslib/lib.
> > You should be able to use the library right from the source, it's static
> so it will be built into GRASS without needing a copy of the laslib.  For
> GRASS configuration, the library will be in that lib folder and includes in
> the laslib/inc folder.
> > On Aug 24, 2015, at 3:47 PM, Michael Barton <michael.barton at asu.edu>
> wrote:
> >> For LASlib compliing, I managed to get past the GEOTIFF problem with
> the following:
> >> cmake -G "Unix Makefiles" -D CMAKE_OSX_ARCHITECTURES="i386;x86_64” \
> >> -D CMAKE_OSX_SYSROOT="/Developer/SDKs/MacOSX10.7.sdk” \
> >> -D GDAL_CONFIG=/Library/Frameworks/GDAL.framework/Programs/gdal-config \
> >> -D
> GEOTIFF_INCLUDE_DIR=/Library/Frameworks/UnixImageIO.framework/unix/include \
> >> -D
> GEOTIFF_LIBRARY=/Library/Frameworks/UnixImageIO.framework/unix/lib/libgeotiff.dylib
> >> But now cmake is complaining about the CMAKE_OSX_ARCHITECTURES flag. I
> don’t know if this harkens back to the similar problem with boost or if
> this is new. I’ve tried both i386 and x86_64 individually and it still
> won’t compile.
> >> Michael
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150915/421c684e/attachment.html>
