[GRASS-dev] r.in.lidar not running in Mac binaries for 7.1
Vaclav Petras wenzeslaus at gmail.com
Wed Sep 16 07:22:26 PDT 2015
On Wed, Sep 16, 2015 at 9:41 AM, William Kyngesburye <woklist at kyngchaos.com>
wrote:
> So the question is if GRASS supports one or the other library or both, or
> does it also use the tools in a script so it doesn't matter.
GRASS uses only the library, not the tools, and is designed/tested/known to
work only with libLAS.
I suppose there never was a need or will to compile it with LASlib which is
coupled with partially non-FOSS LAStools (and you would need the FOSS
libLAS' tools anyway).
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150916/17e5834c/attachment.html>
