[GRASS-dev] [GRASS GIS] #2472: v.in.lidar gives negative point count on large las files
GRASS GIS trac at osgeo.org
Thu Sep 17 18:54:09 PDT 2015
  Reporter:  dnewcomb  |      Owner:  grass-dev@…
      Type:  defect    |     Status:  new
  Priority:  normal    |  Milestone:  7.0.0
 Component:  Default   |    Version:  svn-releasebranch70
Resolution:            |   Keywords:  v.in.lidar  point initial count
       CPU:  x86-64    |   Platform:  Unspecified
Comment (by wenzeslaus):
 Replying to [comment:2 mlennert]:
 > Replying to [ticket:2472 dnewcomb]:
 > > Trying to use v.in.lidar to import points from an las file with
 3531181701 points
 > > `Importing -763785595 points...`
 > A sign of integer overflow. AFAICT, in this particular case this is just
 in the message where a '%d' placeholder is used which represents a signed
 int. But the count of the number of points is defined as unsigned int and
 with larger files this will probably also overflow.
 Changed to `unsigned long long` with `unsigned long` as a fallback in
 r66255. Please test.
 (This supposes usage without topology and attribute table.)
 If the test works, please update the
 [https://grasswiki.osgeo.org/wiki/GRASS_GIS_Performance#Large_vector_data_processing
 wiki] and propose updates to the
 [https://grass.osgeo.org/grass71/manuals/v.in.lidar.html manual] if
 needed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2472#comment:4>
