[GRASS-dev] table with the parser standard options
Luca Delucchi lucadeluge at gmail.com
Wed Sep 23 00:57:36 PDT 2015
On 23 September 2015 at 09:26, Luca Delucchi <lucadeluge at gmail.com> wrote:
> On 19 September 2015 at 11:11, Martin Landa <landa.martin at gmail.com> wrote:
>> Hi,
>> 2015-09-19 10:51 GMT+02:00 Luca Delucchi <lucadeluge at gmail.com>:
>>>> ./parser_standard_options.py -t ../lib/gis/parser_standard_options.c
>>>> -f grass -o
>>>>   File "/usr/lib/python2.7/argparse.py", line 2239, in _get_value
>>>>     raise ArgumentError(action, msg)
>>>> argparse.ArgumentError: argument -t/--text: can't open '': [Errno 2]
>> it seems to be problem with relative path. Luca, could you change it
>> to absolute path?
> tried in r66299, I hope this is fixing the problem in travis ci. Let's see
absolute path didn't work, I also tried to protect the values of the
options but it didn't work too.
The error seems the the option -t/--text is empty, could be a problem
of argparse version?
Is there any way to contact the Travis-CI guys for some support?
I have no other ideas how to fix this problem, specially because it
seems related only to Travis....
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
