[GRASS-dev] [GRASS GIS] #2448: Fontconfig error with cairo on Windows
GRASS GIS trac at osgeo.org
Thu Sep 24 08:44:47 PDT 2015
  Reporter:  annakrat     |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:  7.0.2
 Component:  Display      |    Version:  7.0.0
Resolution:               |   Keywords:  font, text, legend, scale bar
       CPU:  Unspecified  |   Platform:  MSWindows 8
Comment (by hellik):
 Replying to [comment:61 annakrat]:
 > > > where should I see this log? I still can't see any text in the
 legend...
 > Oh I see. Yes I can see there the 2 oks.
 > > some special security rules?  antivirus sw? virtual windows or real
 windows box?
 > I am running windows 10 in a virtual machine, I didn't do anything
 special, I haven't installed any antivirus software. Sorry, I know it's
 frustrating...
 for the record the conversation on the nsis forum:
 http://forums.winamp.com/showthread.php?t=382427
 I've tested the modified installer now on following win boxes with
 different locales:
 win Vista 32bit
 win 7 32bit and 64bit
 win 8.1 64bit
 it works nicely there, so no idea here from my side at the moment what is
 going on ...
 from the nsis forum:
 I don't think .bat files support manifests but if the parent process is
 elevated then the .bat file should be elevated as well.
 I assume you have verified the permissions on the security tab in the
 properties for the files/folders in question on the systems it fails on?
 If it works on some systems and not on others you should probably move
 your investigation to g.mkfontcap.exe...
 can you look at the permissions of the $installdir/etc folder and the
 fontcap file by right click on folder/file -> properties -> security tab?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2448#comment:62>
