[GRASS-dev] .g.proj datum_trans (5514)
Martin Landa landa.martin at gmail.com
Sat Apr 2 05:28:24 PDT 2016
2016-04-02 12:24 GMT+02:00 Martin Landa <landa.martin at gmail.com>:
>>> Is there anything I am doing wrong or it's a bug? Thanks, Martin
>> This part is still buggy.
> I see, I will try to take a look during this weekend. Ma
Ok, it's `-t` flag again.
$ g.proj epsg=5514 datumt=-1
1
Used in whole S_JTSK region
towgs84=589.000,76.000,480.000
Default 3-Parameter Transformation (May not be optimum for older
datums; use this only if no more appropriate options are available.)
2
Used in Czech Republic
towgs84=570.8,85.7,462.8,4.998,1.587,5.261,3.56
Accuracy about 1m
3
towgs84=572.213,85.334,461.94,-4.9732,-1.529,-5.2484,3.5378
Accuracy about 1m
4
Used in Slovakia
towgs84=485,169.5,483.8,7.786,4.398,4.103,0
Accuracy about 1m
But
g.proj epsg=5514 datumt=2 -p
-PROJ_INFO-------------------------------------------------
towgs84    : 589,76,480,0,0,0,0
still gives me default datum transformation params.
Adding `-t` flags leads to correct result.
g.proj epsg=5514 datumt=2 -tp
towgs84    : 570.8,85.7,462.8,4.998,1.587,5.261,3.56
I don't know why `-t` flags is neeed here, selected parameters by
`datumtrans` should be enough here.
Any idea? Thanks. Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
